Sip Posted August 17, 2010 Share Posted August 17, 2010 Hi Need the axle number in order to do the brakes, any idea where I might find it on the front axle? Cheers Neil Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 17, 2010 Share Posted August 17, 2010 Hi Need the axle number in order to do the brakes, any idea where I might find it on the front axle? Cheers Neil It's normally stamped-in somewhere in the middle of the "longer half", same on the back. You may need a wire brush ... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 17, 2010 Share Posted August 17, 2010 Looking from the front IIRC its on top of the right hand side of the axle, the long tube side. Will probably need a wire brush to make it readable Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 17, 2010 Share Posted August 17, 2010 Is there an echo in here . Clicked reply and was slightly distracted as I'm at work, then posted Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 17, 2010 Share Posted August 17, 2010 ... posted ... posted ... posted Quote Link to comment Share on other sites More sharing options...
