rangeclassic13 Posted September 17, 2010 Share Posted September 17, 2010 , I would want booster my tidy up 300 tdi, having to delete(eliminate) the egr, the catalytic, and to go(take) up a filter has air(sight) to do the twist, I wish to make settle(adjust) my turbo and the pump I also intend to go(take) up a bigger intercooler. IF you have information on the ideal regulation, I am a buyer. BRUNO Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted September 17, 2010 Share Posted September 17, 2010 If your TDi is the older non-edc type you can tweak the fuel pump, raise the boost pressure a little bit and if you don't have Air conditioning you can fit a HOOGE intercooler. Mine is the same size as the radiator To raise the boost I used an adjustable boost control valve which is easier to adjust at the road side. It also prevents waste gate creep so it improves mid-boost performance making the car more sprightly. Try small imcreases in boost and fuel pump settings, fit a boost guage to check the pressure too. Oh and remove the particle filter in the exhaust. Quote Link to comment Share on other sites More sharing options...
taurion Posted September 19, 2010 Share Posted September 19, 2010 Look at http://www.landroverfaq.com/viewtopic.php?t=21 . It is for the VM but the pump intercooler and advice is the same. Voir http://www.landroverfaq.com/viewtopic.php?t=21. (En français) C'est pour la VM mais pompe , intercooler et conseil est la même. Bon Courage Quote Link to comment Share on other sites More sharing options...
rangeclassic13 Posted September 25, 2010 Author Share Posted September 25, 2010 BLUES RANGE ROVER, Thank you for the information, on I tidy up I am going to delete(eliminate) the radiator of the air conditioning because I never serves me as it, not rather warmly the summer, and she(it) consumes too much power. I am thus going to make settle(adjust) the pump and the turbo and go(take) up a bigger intercooler. What is this room(part,play):le stimulating lid of pressure and or takes place you he(it) in the engine??. BRUNO Quote Link to comment Share on other sites More sharing options...
