Scruffyhippo Posted September 17, 2010 Share Posted September 17, 2010 Does anyone know if a TD5 back loading door will fit a 300TDi, or, does anyone know of an after market third brake light that fits tight to the glass like the TD5 one. I'm going to black out the rear window and fit a grill for security and would like to sort out the brake light first. I.ve been offered a complete TD5 door for £40.00 so cost is not the problem Quote Link to comment Share on other sites More sharing options...
piper109 Posted September 17, 2010 Share Posted September 17, 2010 I had heard (but get confirmation) that the only body part the D2 has in common with the D1 was the back door. Quote Link to comment Share on other sites More sharing options...
fatbloke Posted September 17, 2010 Share Posted September 17, 2010 Late 300 tdi's had third level brake lights Quote Link to comment Share on other sites More sharing options...
Scruffyhippo Posted September 17, 2010 Author Share Posted September 17, 2010 Thanks piper and fatbloke that's useful info Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted September 17, 2010 Share Posted September 17, 2010 I had a td5 and 200 door here together recently, they are the same size and shape, but the curve is slightly different. Quote Link to comment Share on other sites More sharing options...
mahon257 Posted September 18, 2010 Share Posted September 18, 2010 Does anyone know if a TD5 back loading door will fit a 300TDi, or, does anyone know of an after market third brake light that fits tight to the glass like the TD5 one. I'm going to black out the rear window and fit a grill for security and would like to sort out the brake light first. I.ve been offered a complete TD5 door for £40.00 so cost is not the problem They absolutley don't match - I have a 300TDI 1996 "ES". Had to buy a replacement door - like you, managed to get one from a TD5. The doors are the same shape /size - even the hinges are in the same position... BUT the latch ain't! So you can't shut the door. Only solution would be to cut out the lock mechanism, and re-weld it in another position (which would clearly be a waste of time!). I ended up scrapping the TD5 door, and buying another one - for a 300TDI! Hope that helps Nick Quote Link to comment Share on other sites More sharing options...
