Pudock Posted September 21, 2010 Share Posted September 21, 2010 Some time ago I put the motor into the garage to get the head gasket done. When it came back I noticed that it was idling slightly faster but had lost a some of its engine breaking. What could cause the loss in braking ability? Does the higher idling speed have anything to do with it? Thanks Quote Link to comment Share on other sites More sharing options...
pete3000 Posted September 21, 2010 Share Posted September 21, 2010 Yes turn the idle down a bit, idle figures should be in the haynes/service book. Set it when cold though as it will be lower on cold start. May not start well in cold weather if you set it when engine is hot. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 21, 2010 Share Posted September 21, 2010 might even be something really simple like the throttle cable not fully releasing? Quote Link to comment Share on other sites More sharing options...
Pudock Posted September 21, 2010 Author Share Posted September 21, 2010 Thanks guys, throttle cable is fine by the way. I'll adjust the screw a little tomorrow. Quote Link to comment Share on other sites More sharing options...
