ivanlrlukic Posted September 30, 2010 Share Posted September 30, 2010 I have a posibility to acquire two 2-door RRC's which are not in a great shape. Idea is to use one until other one is torn into pieces in order to free chassis which would be sand blasted and welded. Now comes the main point (by which I would decide if it's worth to jump to the whole mess). How difficult is to change chassis under the body? Is it possible to unscrew complete running body, lift it and place it to different chassis? Engine, gearboxes and axles should not be a big deal. Regards, Ivan. Quote Link to comment Share on other sites More sharing options...
teslo Posted October 1, 2010 Share Posted October 1, 2010 Is it possible to unscrew complete running body, lift it and place it to different chassis? If chassis are the same, then yes... Quote Link to comment Share on other sites More sharing options...
ivanlrlukic Posted October 2, 2010 Author Share Posted October 2, 2010 If chassis are the same, then yes... Better one is early '85, other is a bit older, around '79. Are those chassis interchangeable? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted October 4, 2010 Share Posted October 4, 2010 Yeap, the body mounts didn't change AFAIK. Fork truck through the doors works well. Wind the windows down though. Quote Link to comment Share on other sites More sharing options...
