Frogland Posted October 4, 2010 Share Posted October 4, 2010 Is there a trick for getting the wipers to sit properly at the bottom of the windsreen when they're off ? I keep taking mine off and readjusting them they either sit too high on the windscreen or they want to rest on the bulkhead . Quote Link to comment Share on other sites More sharing options...
oakesy Posted October 5, 2010 Share Posted October 5, 2010 Possible they're worn out on the driver side. Mine are like that, gave trying in the end. Quote Link to comment Share on other sites More sharing options...
crwoody Posted October 5, 2010 Share Posted October 5, 2010 Sounds like either the adaptor fittings on the ends of the spindles have come loose or there's just too much play or wear in the cable drive gearboxes. On the gearbox there is back plate which holds the connecting tubes that the cable runs through, if these work loose you'll get a similar effect. If you take the dash top off, you can get to the gearboxes and see what's going on and maybe tighten it all up, it's a bit fiddly but do-able. Quote Link to comment Share on other sites More sharing options...
