russpaul Posted October 5, 2010 Share Posted October 5, 2010 Problem when pulling away and then moving into second and gathering speed ive got a noise that is best described as like a loose jubilee clip around front propshaft, tends to die away as more speed and gear change achieved. This afternoon thought I would try in low ratio and found it hard to get any engagement at all, did in the end but high and low not very positive at all. Can anyone give me any pointers please Quote Link to comment Share on other sites More sharing options...
defender dinky Posted October 5, 2010 Share Posted October 5, 2010 Problem when pulling away and then moving into second and gathering speed ive got a noise that is best described as like a loose jubilee clip around front propshaft, tends to die away as more speed and gear change achieved. This afternoon thought I would try in low ratio and found it hard to get any engagement at all, did in the end but high and low not very positive at all. Can anyone give me any pointers please hi, i had this noise jingling on my prop turned out to be mud sheild on prop flange t/box end, took prop off and retighten the big nut, defender dinky Quote Link to comment Share on other sites More sharing options...
russpaul Posted October 6, 2010 Author Share Posted October 6, 2010 hi, i had this noise jingling on my prop turned out to be mud sheild on prop flange t/box end, took prop off and retighten the big nut, defender dinky Thanks, will checkout asap Quote Link to comment Share on other sites More sharing options...
