Disco relays, where are they please?
Landowner
Dipped Headlamps gone out on Disco, any idea where the relays are please
Haynes manual is absolutely flippin useless, or maybe it's me
You think it would be easy to find out how the headlamps are wired and where the relays are without having to spend half an hour reading through it and then giving up. :rolleyes:
As far as I know, the pre 95 model has no relay for the lights and it runs direct over the switch in the stalk. 95 and after the relay is behind the panel on the passenger side, There are two there and one of them is for the lights and the other for the washer pump.
ATB
Michael
Remove the steering column cowling and check the switch wires. Mine had broken off.
Regards
Just a flasher relay and one other under steering column, hoping it's the one other.
Might be a broken wire though so will try that next. :)
Well, my mate Tom has found the problem.
A black wire had broken off the switch in the stalk. Thanks Bear :)
