Gerry1964 Posted October 7, 2010 Share Posted October 7, 2010 Hi all, just had to have a new TDI engine fitted, was pretty lucky and managed to source one for just £1450 with 42k on the clock, but now i need to find the engine number so i can change it on the logbook, anyone have any ideas where this could be??? I've looked everywhere Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 7, 2010 Share Posted October 7, 2010 Is it a Tdi or a Discovery 2 because it can't be both... Discovery 2 would have a Td5 engine and be from 1999 to 2004 model year, a Tdi will be either a 200Tdi from 1989 to 1994 model year, or a 300Tdi from 1995 to 1998 model year. If it is a 300Tdi then it is stamped on a flat horizontal face on the front RH side of the engine, don't have one to look at but it would be more or less underneath the No. 1 injector position from memory. May require a scrub up to reveal it. Quote Link to comment Share on other sites More sharing options...
Gerry1964 Posted October 7, 2010 Author Share Posted October 7, 2010 Is it a Tdi or a Discovery 2 because it can't be both... Discovery 2 would have a Td5 engine and be from 1999 to 2004 model year, a Tdi will be either a 200Tdi from 1989 to 1994 model year, or a 300Tdi from 1995 to 1998 model year. If it is a 300Tdi then it is stamped on a flat horizontal face on the front RH side of the engine, don't have one to look at but it would be more or less underneath the No. 1 injector position from memory. May require a scrub up to reveal it. I do apologise, its a TD5 engine i must of rushed it a bit there somewhere. its on a 2003 discovery 2, any ideas?? Quote Link to comment Share on other sites More sharing options...
M&S Posted October 7, 2010 Share Posted October 7, 2010 And if it's a TD5 it's under the exhaust manifold (everything is under the exhaust or inlet manifold! ) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 7, 2010 Share Posted October 7, 2010 Yes as above - on the LH side of the engine underneath the exhaust manifold. Lovely place to get at to clean it up if its a bit rusty or covered in oily goo.. Quote Link to comment Share on other sites More sharing options...
