Jase Posted October 8, 2010 Share Posted October 8, 2010 Hi All, I'm new to this forum and am in need of help. I'm busy fixing up a 1980 Series 3 109 Hardtop. I've been trying unsuccesfully to remove the distance piece on the front left stub axle using a 4pound hammer and cold chisel. It's made a deep groove in the distance piece but the dam thing won't move! I'm sure it's the removeable type but now I'm starting to doubt myslef. I've attached a pic if someone can confirm that it should be removeable? If it is removeable then are there any other suggestions as to how to get it off? Thanks, Jason (Durban, South Africa) Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 8, 2010 Share Posted October 8, 2010 If it's a 1980 vehicle then depending on exactly when in 1980 it was made it could be either! I'm afraid to say it looks like a fixed one in the picture. Are both hub bearings the same size? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 11, 2010 Share Posted October 11, 2010 It looks just like the later stubs on my 109 as i changed them for the later type to get the oil catcher fitment. The stub in the picture has a radius at the rear of the seal collar where it meets the back flange and it has the cut out on the flange face for the oil drain from the catcher rings. So now that you have attacked it with a cold chisel its scrap. Quote Link to comment Share on other sites More sharing options...
Jase Posted October 16, 2010 Author Share Posted October 16, 2010 Thanks guys. It is the later type, has same size inner and outer bearings. It was scrap before I 'attacked' it as the distance piece was badly pitted from sitting idle for years. I have another question. Will a Stage One front stub axle fit? I've checked the parts catalogue and the part numbers for the Stage One stub axles are FRC3100 or FRC3917 (later). This is different to the Series 3 stub axle for which the part number is FRC3925. However, the part numbers for the bearings, hub seal, and hub are exactly the same for both the Stage One and Series 3 109 (post Oct 1980). The only difference I see is that the stage one stub axle has a copper bush as well as a rubber seal. Will the copper bush cause a problem? The reason I ask is because I've managed to find a second hand Stage One Stub axle but not a Series 3 one. Jason Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 16, 2010 Share Posted October 16, 2010 I suspect that as the pt no is for the assembly of stub/bush/seal that the actual stubs are the same. If the one you have found is cheap its worth doing a full comparison with seals and bush removed, and posting the results on here for the rest of us. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 17, 2010 Share Posted October 17, 2010 The stub axles will be different for the Stage 1 V8 axles, as they use CVs, so surely they have the brass bush in them for CV location? Like 90/110 do. Whether that would affect your ability to use them with a normal UJ'd Series axle, I don't know I'm afraid Quote Link to comment Share on other sites More sharing options...
Jase Posted October 25, 2010 Author Share Posted October 25, 2010 Hi All, Just to let you know, I bought the stub axle from the S3s and it's identical to my old stub axle so there shouldn't be any problems fitting it. Thanks for all your help. Jason Quote Link to comment Share on other sites More sharing options...
