Davecrx Posted October 12, 2010 Share Posted October 12, 2010 I've just converted my disco from tdi to V8 and fitted megasquirt. I'm now making the fuel lines and installing the external high flow fuel pump but I can't decide where to mount the pump. The two ideas I have had are Mounting the fuel pump under the boot floor where the sediment-tank was or in the engine bay on the inner arch?? Thanks for your input in advance. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 12, 2010 Share Posted October 12, 2010 High flow or high pressure or both? Many EFI pumps don't like having to draw fuel uphill, so that may influence your decision. Personally I'd think about keeping the sedimenter and using it as a swirl-pot, if it's suitable. Quote Link to comment Share on other sites More sharing options...
Davecrx Posted October 13, 2010 Author Share Posted October 13, 2010 its both a high flow/pressure and also seems very good at lifting fuel from the tank. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 13, 2010 Share Posted October 13, 2010 its both a high flow/pressure and also seems very good at lifting fuel from the tank. That's sorted then - where did you find it / what's it from? Quote Link to comment Share on other sites More sharing options...
Davecrx Posted October 13, 2010 Author Share Posted October 13, 2010 i have had the pump ages but never used it. it came in a turbo kit i brought when i turbocharged my Honda, but i upgraded my intank pump instead. Quote Link to comment Share on other sites More sharing options...
