Wolfie69 Posted October 21, 2010 Share Posted October 21, 2010 Hi I was wondering if anybody on here can help,I was driving home from work today and noticed my oil warning light flashing.It was only a short drive but by the time I got home it had gone into limp mode and the light is on continuiously.I did the obvious and dipped the oil it was a little bit low but still between the marks,I topped it up anyway but this has not made a difference it is still in limp mode with the light on.So a.ny help would be most appriecated.Thanks Quote Link to comment Share on other sites More sharing options...
SiWhite Posted October 22, 2010 Share Posted October 22, 2010 I'd advise not driving it until you've dropped the sump and checked the oil pump drive sprocket. The oil pump is powered by a chain driven from the crankshaft, and the bolt holding the sprocket in place can work loose and fall off, leaving no oil pressure. Driving it like this will ruin the engine. Quote Link to comment Share on other sites More sharing options...
Wolfie69 Posted October 22, 2010 Author Share Posted October 22, 2010 Its parked up but is being towed to the garage later today Quote Link to comment Share on other sites More sharing options...
dooroy Posted October 27, 2010 Share Posted October 27, 2010 What year is your Disco - the early Td5's were prone to this type of problem due to bolt holding oil pump sprocket coming loose and sprocket falling off. Complete loss of oil pressure . However I read that anyone it happened to had resulted in a wrecked engine - no matter how quickly the driver switched off ; so in your case its likely to be something else - or maybe sprocket is just loose and giving some oil pressure . Quote Link to comment Share on other sites More sharing options...
Wolfie69 Posted October 27, 2010 Author Share Posted October 27, 2010 It is a 1999 with 180000 miles on the clock but even with the problem the engine still sounded sweet.It was being looked at yesterday by my local 4x4 garage so hopefully I will get some news today. Quote Link to comment Share on other sites More sharing options...
Wolfie69 Posted October 30, 2010 Author Share Posted October 30, 2010 Verdict engine has no oil pressure at all and turbo blown,Disco is now parked at my parents awiating funds and time.I am having to use a pug 205 now. Quote Link to comment Share on other sites More sharing options...
mayur Posted October 31, 2010 Share Posted October 31, 2010 If you know the turbos blown try this block the turbo oil feed line and push and hold the waste gate to the fully open position ! (helps stop bits off the turbo getting stuck in the cat!) and start the engine and see if the oil light goes out, this way you know if the bearings in the engine arnt gone which will save you guessing if the turbos the only problem Quote Link to comment Share on other sites More sharing options...
