disco_sammy Posted November 22, 2010 Share Posted November 22, 2010 Hello I've got myself a tow bar off the 'bay but it didn't have any electrics with it. I've picked up a socket and some cable but just wondered if anyone knew exactly the type of plug required to plug into the point near the ofside light, rather than scotch locking it. I've found a thread with the pin layout but not the plug type. It's a W reg Td5 if that makes a difference? Cheers Sam Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 23, 2010 Share Posted November 23, 2010 My 1988 RRC had the round one but in the 90s LR started using a spade style socket, You can wire it up with Lucar crimp terminlas and white grease to seal it. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted November 23, 2010 Share Posted November 23, 2010 Hello I've got myself a tow bar off the 'bay but it didn't have any electrics with it. I've picked up a socket and some cable but just wondered if anyone knew exactly the type of plug required to plug into the point near the ofside light, rather than scotch locking it. I've found a thread with the pin layout but not the plug type. It's a W reg Td5 if that makes a difference? Cheers Sam The connector on the vehicle loom is a - Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Female Housing, Part No. F(6195-0170) The mating half you're looking for is a - Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Male Housing, Part No. M(6195-0173) You will also need 7 x 090(2.3mm) and 2 x 187(4.8mm) Male Terminals, with the appropriate Wire Seals for each Terminal (I have the Part No's if you want them ) I haven't found anywhere selling the connector shells or the 187(4.8mm) terminals in sensible quantities, only the 090(2.3mm) terminals. 1. You could do as suggested in the post above - use individual 2.3mm and 4.8mm male terminals pushed into the connector terminals but, IMHO, that's a bit of a bodge 2. You could change the connector for a more readily available version of the Sumitomo DL Sealed Series connector - http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SMDL/smdl.html 10-Way Sumitomo DL Sealed Series 090 Connector, Female and Male - This would enable you to just transfer the 7 x 090 terminals on the vehicle loom to the new connector shell and, because you would be down-sizing the Aux. Live and Earth (pins 6 and 9), double-up the earth connection and down-rate the fuse on the Aux. Live. 3. You could just buy the Land Rover 12N Kit STC50081 Which plugs staight in, with no fuss . Quote Link to comment Share on other sites More sharing options...
disco_sammy Posted November 23, 2010 Author Share Posted November 23, 2010 Cheers Paul, that's spot on. Quote Link to comment Share on other sites More sharing options...
