ashtray Posted November 22, 2010 Share Posted November 22, 2010 Ok so i noticed some rust on the bottoms of my door frames today and decided to take the door cards off to investigate further. You guessed it, i found more rust! So they are structually sound still, but looking pretty messy and if i leave them i will be needing new doors eventually. What do you reckon i should do and what are the best products out there to "cure" and prevent rust. Obviously i will need to get rid of as much rust as possible using a wire brush slash similar item. Also whilst i was there i noticed a water collecter and tube assembly that looks like its fallen off the inside of the door, looks like a hopeless piece of kit as it just collects water from the window seal and then lets it drip on the door bottom again. The outer door skins are in excellent condition so i dont really want to replace the frame and transfer the door as that just looks like a MISSION, and im sure that in the process i'll wreck the skins. So... What do you know about rust? Thankyou! Ash Quote Link to comment Share on other sites More sharing options...
greenpaint Posted November 23, 2010 Share Posted November 23, 2010 Dinatrol rust converter. Expensive but its good Quote Link to comment Share on other sites More sharing options...
WarPig Posted November 23, 2010 Share Posted November 23, 2010 Took my doors to http://www.landroversuk.co.uk/workshop.html Not cheap, but it suited me to do it this way at the time. I can provide photos of before and after if required. Quote Link to comment Share on other sites More sharing options...
ashtray Posted November 23, 2010 Author Share Posted November 23, 2010 ooo they look good! Anyone know if its possible to get hold of repair sections for the lower frames? Definately getting hold of some dinitrol wax. I have used hammerite kurust before but it did naff all Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 23, 2010 Share Posted November 23, 2010 http://www.yrm-metal-solutions.co.uk/015-door-repair-section-11-p.asp Door frame can be repaired with that, then put the skin back on and bob's your uncle Quote Link to comment Share on other sites More sharing options...
ashtray Posted November 23, 2010 Author Share Posted November 23, 2010 mmm looks fun! and if i ruin it ill take it to land rovers uk! Thanks all! Quote Link to comment Share on other sites More sharing options...
