TonkaIIa Posted November 25, 2010 Share Posted November 25, 2010 Hi all, I'm currently having problems bleeding the clutch I've converted the old single-line brake and clutch pedals/system for a later series III. I filled the clutch reservoir with fluid and opened the bleed nipple at the slave cylinder and had someone depress the pedal, after several times no fluid came out. I've left this for a couple of days and still the same. It all seemed to work OK when I removed it, could this be down to the piston inside the clutch master cylinder not working?? or could it be something else?? Any advise would be grateful. Cheers Gary Quote Link to comment Share on other sites More sharing options...
rtbarton Posted November 25, 2010 Share Posted November 25, 2010 Check you have some free movement at the pedal before it starts to push the master cylinder pushrod. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 26, 2010 Share Posted November 26, 2010 Check you have some free movement at the pedal before it starts to push the master cylinder pushrod. Clutch hose knackered? G. Quote Link to comment Share on other sites More sharing options...
