DiscofeverLangport Posted November 28, 2010 Share Posted November 28, 2010 Hi everyone. I have a 2003 Discovery TD5 which I have owned for a few months. In that time I have taken it off road quite a bit but have found that when driving through water of maybe no more than 8 inches or so at fairly low speed the engine seems to splutter afterwards when you put your foot hard down if pulling away from a junction for example. Its the same sort of thing you get when a petrol engine car gets a wet distributor and starts spluttering. It clears after a while but I'm sure a vehicle like this shouldn't suffer from going through fairly shallow water. I am going to put a snorkel on the disco but I dont know that this will definately solve the problem. If water was getting to the air intake surely the problem would be more serious than spluttering for a while. What does anyone think? Quote Link to comment Share on other sites More sharing options...
Wolfie69 Posted November 29, 2010 Share Posted November 29, 2010 I also had issues with water although I went a bit deeper (the back wave washed over my bonnet),the problem is the ecu getting wet I would check to see if you are getting any water up through the inner wing under the ecu. Quote Link to comment Share on other sites More sharing options...
M&S Posted November 29, 2010 Share Posted November 29, 2010 I have the same problem. Check your airfilter, I'll bet it's wet. I don't know why but mine sucks water in from a puddle Quote Link to comment Share on other sites More sharing options...
DiscofeverLangport Posted November 29, 2010 Author Share Posted November 29, 2010 Hi, I have been deeper, over the bonnet stuff which resulted in the same problem but what worried me was that it was spluttering after wading fairly shallow stuff, for a disco at least!! Quote Link to comment Share on other sites More sharing options...
DiscofeverLangport Posted November 29, 2010 Author Share Posted November 29, 2010 [ Hi, Thanks for the advise, I will check the air filter and look at where the ECU is to see if its gettng wet. Quote Link to comment Share on other sites More sharing options...
