craig Posted December 2, 2010 Share Posted December 2, 2010 i have a 110 csw, the front doors have key holes as does the rear door. the locks are real poor and can be opened with any key. would new ones be just as bad or can i get some higher security ones that i can just replace? cheers Quote Link to comment Share on other sites More sharing options...
mr_mcp Posted December 2, 2010 Share Posted December 2, 2010 I'd personally just get some new standard barrels, your current ones just sound worn. The trouble with getting fancy locks means a potential theif may just look for another weakness so you may not be any better off. Quote Link to comment Share on other sites More sharing options...
cookie64 Posted December 2, 2010 Share Posted December 2, 2010 ui changed my barrels earlyer int he year, super eay to do and you cvant get a set of fleebay dirt cheap. makes it easyer to do if you drill a small hole in the bracketry that holds your window mechanism so you can get a screwdriver on to the inside of the lock easier tom Quote Link to comment Share on other sites More sharing options...
hobson Posted December 2, 2010 Share Posted December 2, 2010 They sound worn, so i'd stick some new ones on. and for the price difference i'd go genuine. the subject of new improved door locks has come up several times, but even if you fitted the best, most secure door locks ever, or welded the doors shut, it doesn't stop a theif using a brick or tap hammer to smash the window. i'd make sure the door locks work (as well as they can on a landy!) and don't leave things on show to discourage the opportunists, and use something highly visible like a disklok to discourage it getting nicked. HTH Quote Link to comment Share on other sites More sharing options...
craig Posted December 2, 2010 Author Share Posted December 2, 2010 cheers for the replies, ill just fit some new barrels Quote Link to comment Share on other sites More sharing options...
craig Posted December 2, 2010 Author Share Posted December 2, 2010 just looked to buy some, there are sets of three available, is the rear door the same barrel type?? cheers Quote Link to comment Share on other sites More sharing options...
