90MAD Posted December 8, 2010 Share Posted December 8, 2010 cheers all sorted Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted December 8, 2010 Share Posted December 8, 2010 The sleeve is part of the alternator. It slides in and out to meet the back of the engine bracket. Does the alternator swivel at all? Quote Link to comment Share on other sites More sharing options...
western Posted December 8, 2010 Share Posted December 8, 2010 the sleeve is the sliding bush in the rear end mount, it's meant to be there so the alternator can be fitted in the correct place for the drive belt, with all the bolts out, move the adjusting link clear & rock the alternator body forwards/backwards or put a prybar between the rear mount & bracket to prise the bush back, it will lift out. Quote Link to comment Share on other sites More sharing options...
90MAD Posted December 8, 2010 Author Share Posted December 8, 2010 the sleeve is the sliding bush in the rear end mount, it's meant to be there so the alternator can be fitted in the correct place for the drive belt, with all the bolts out, move the adjusting link clear & rock the alternator body forwards/backwards or put a prybar between the rear mount & bracket to prise the bush back, it will lift out. cheers for the info guys got it out so now can drop it off and get the new diode put in and abit of a clean Quote Link to comment Share on other sites More sharing options...
