scabbydisco Posted January 4, 2011 Share Posted January 4, 2011 the rear door will mostly open ok, but sometimes will come off the latch but not open, as if the lock hasn't opened correctly. Also, the drivers door needs slight upward lift while opening door latch to open properly. any suggestions for a repair? thanks. Quote Link to comment Share on other sites More sharing options...
teabag Posted January 4, 2011 Share Posted January 4, 2011 Worn hinges can give problems but maybe all that is required is a slight adjustment to the lock striker plates. Quote Link to comment Share on other sites More sharing options...
