defender dinky Posted January 4, 2011 Share Posted January 4, 2011 hi all, 200 tdi, noticed today that my power steering fluid has overflowed again , first time about a month ago, coming out of the top of reservor tank, why????? dd Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2011 Share Posted January 4, 2011 probably overfilled the reservior, should be between the 2 raised lines on the cap dipstick when fluid is cold. or you have a air leak into the system. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted January 4, 2011 Author Share Posted January 4, 2011 probably overfilled the reservior, should be between the 2 raised lines on the cap dipstick when fluid is cold. or you have a air leak into the system. the last time it happened i released the bleed nipple a touch no fluid came out so i took the nipple out altogether and it took about five minutes before fluid showed, that was without engine running, so you maybe right air has had time to build back up i guess, cheer's western dd Quote Link to comment Share on other sites More sharing options...
western Posted January 5, 2011 Share Posted January 5, 2011 sounds like time for a full bleed & fluid fill to the correct level. Quote Link to comment Share on other sites More sharing options...
