AJL Posted January 7, 2011 Share Posted January 7, 2011 Hi After attempting to jump start my TD5 Defender which had a dead battery it now appears that the factory fitted alarm / immobilizer is preventing starting when the jump cables are attached all systems came on lights etc etc however the red light keeps flashing when i turn the key the light shows an engine with a lightening strike across it. I'm guessing this is the immobilizer / engine management system warning light. I've tried blipping the alarm key fobs turning the key through various positions but everything has failed. I'm sure I heard somewhere that there is a specific reset procedure can anyone please advise? Many thanks James Quote Link to comment Share on other sites More sharing options...
western Posted January 7, 2011 Share Posted January 7, 2011 Drop your e.mail address to me via PM & I'll scan the procedure from the Td5 owners handbook, Quote Link to comment Share on other sites More sharing options...
AJL Posted January 7, 2011 Author Share Posted January 7, 2011 Drop your e.mail address to me via PM & I'll scan the procedure from the Td5 owners handbook, Thanks Western PM Sent Quote Link to comment Share on other sites More sharing options...
western Posted January 7, 2011 Share Posted January 7, 2011 Reply PM & the e.mail with the relevant page sent , hope it helps. Quote Link to comment Share on other sites More sharing options...
AJL Posted January 7, 2011 Author Share Posted January 7, 2011 OK I've got the procedure which Ralph so quickly kindly sent, problem is I'm in Bucharest, Romania and my user manual and 4 digit immobilizer reactivation code is god knows where without going to a main stealers here in Bucharest is there any way I can override this maybe with the use of Nanocom or test book? Basically without the code in a foreign country i'm a bit screwed I guess if pushed I could take my V5 and ID to the LR Stealers but would they have a record of my immobilizer code on their computer? Many thanks in advance of advice James Quote Link to comment Share on other sites More sharing options...
western Posted January 7, 2011 Share Posted January 7, 2011 you should be able to interogate the ECU to retrieve the code, most likely in the alarm/immobiliser ecu. main dealer should be able to get it from the factory via the LR system Quote Link to comment Share on other sites More sharing options...
AJL Posted January 7, 2011 Author Share Posted January 7, 2011 you should be able to interogate the ECU to retrieve the code, most likely in the alarm/immobiliser ecu. main dealer should be able to get it from the factory via the LR system Thanks Ralph Quote Link to comment Share on other sites More sharing options...
stuck Posted January 7, 2011 Share Posted January 7, 2011 "Nanocom or test book" Could anybody tell me if either of these is diagnostic software? Not expecting a post on here but a PM would be appreciated. Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
western Posted January 8, 2011 Share Posted January 8, 2011 AFAIK both are diagnostics equipment Quote Link to comment Share on other sites More sharing options...
