simonr Posted January 11, 2011 Share Posted January 11, 2011 I'm wanting to use a Disco rubber doughnut CV joint to connect two bits of my Eleccy Freelander together. It needs a bit of vibration damping as well as allignment and these should be ideal. Do any of you who have converted from these to 'proper' prop-shafts, still have the bit that normally bolts to the diff going spare? I was going to machine something - but looking at them, they are perfect as is! If so, could we do a swap? Si Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 11, 2011 Share Posted January 11, 2011 I'm wanting to use a Disco rubber doughnut CV joint to connect two bits of my Eleccy Freelander together. It needs a bit of vibration damping as well as allignment and these should be ideal. Do any of you who have converted from these to 'proper' prop-shafts, still have the bit that normally bolts to the diff going spare? I was going to machine something - but looking at them, they are perfect as is! If so, could we do a swap? Si I should think Nige must have a few after some of his recent battles. Quote Link to comment Share on other sites More sharing options...
