Sgt Posted January 18, 2011 Share Posted January 18, 2011 Hi folks, the heated front screen on my 2002 D2 Td5 will not work!! It's not the fuse, does anyone know of anything else that may cause it to stop working? Also, when cold, the auto box takes ages to reach top gear, travelling at 60 mph, for some time before it changes up, well into 3000rpm sometimes. Should this be happening? When warm I can coax it into top at below 50mph? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 18, 2011 Share Posted January 18, 2011 The revs dropping into "top gear" is probably actually the torque converter lock engaging in 4th, and if so that is correct operation, it doesn't engage till the engine and gearbox have warmed up a bit but once it is warm will lock in/out on demand. No idea on the screen but have you got power to the screen i.e. at the terminals in the corners? Quote Link to comment Share on other sites More sharing options...
M&S Posted January 18, 2011 Share Posted January 18, 2011 One half of my screen stopped working yesterday...it's not the fuse and I'm wondering if it's because it's leaking. I'd have hoped the connectors could withstand some condensation and water though Mines going in on Tuesday for a refit, fingers crossed it'll be fourth time lucky for me (and them!) Quote Link to comment Share on other sites More sharing options...
nicks90 Posted January 19, 2011 Share Posted January 19, 2011 we had one half of the screen stop working a couple of years ago - it was the connector under the bonnet at the bottom right of the screen. it had badly corroded and let the smoke out and melted the plastic. cut it off and put a new heavy duty connector on it, job sorted. Quote Link to comment Share on other sites More sharing options...
Sgt Posted January 20, 2011 Author Share Posted January 20, 2011 Thanks for the suggestions, I will give them a look. Paul. Quote Link to comment Share on other sites More sharing options...
M&S Posted January 23, 2011 Share Posted January 23, 2011 Thanks Nick, will give that a check also. Quote Link to comment Share on other sites More sharing options...
