Sidepanel Brackets
need4speed
As title. On the inside of defender (van) sidepanels there are rivetted brackets top and bottom at the front. I was looking to replace the bottom one as mine is bent out of shape. Ive looked at the defender parts book but cant see the bracket listed. Will i just have to remove / replace mine as best i can or is the part available?
Phil
thinking if these brackets are rivetted on, they most likely are classed as part of the upper side panel & therefore are not listed a a seperate replaceable part.
my parts book/microcat doesn't show any internal diagram of the upper bodyside panels, just the external side.
probably best to remove & straighten the existing brackets.
