fatforbes Posted January 28, 2011 Share Posted January 28, 2011 Having a bit of trouble with my 96 defender 300tdi. It's having some trouble starting, it takes 4 or 5 attempts to get it going, it sounds like it wants to go but instantly dies. I have checked all the glow plugs and only 1 needed replacing which I've done. It doesn't seem to matter if it's hot or cold. Any ideas?? I'm also having trouble with the steering. The steering box was leaking from what I think is the rack & pinion adjuster (big flat bladed screw driver fitting on the side of the box) so I removed it and put some PTFE tape on then put it back again but since I did that I can't get my steering right, It's either floaty and all over the road or feels like I've got cement in the steering system. The box is only 2 years old and it's a reconditioned one. Quote Link to comment Share on other sites More sharing options...
Frax Posted January 28, 2011 Share Posted January 28, 2011 Drain or change the fuel filter it may have water in it. Frax Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 28, 2011 Share Posted January 28, 2011 Leak off pipes, and small filter in return pipe on pump.Air leak on fuel pipes Quote Link to comment Share on other sites More sharing options...
simonb Posted January 28, 2011 Share Posted January 28, 2011 If it doesn't start 1st thing in the morning but is usually ok for the rest of the day, it is probably the lift pump which is failing. The internal valves go allowing the fuel to drain back overnight. Had the same problem on mine a few years back. Quote Link to comment Share on other sites More sharing options...
