jagwit Posted February 1, 2011 Share Posted February 1, 2011 Is it possible to fit Disco 2 door panels into a Disco 1? The D2 door panels have good speakers which I want to use in my Disco 1. The inside door handle seems a bit different. Quote Link to comment Share on other sites More sharing options...
teabag Posted February 2, 2011 Share Posted February 2, 2011 Well Land Rover said that every D2 panel was different to that of the D1 when the D2 was introduced, so I would say no. Quote Link to comment Share on other sites More sharing options...
jiginc Posted February 4, 2011 Share Posted February 4, 2011 Rear door is the same but all others are not. Quote Link to comment Share on other sites More sharing options...
jagwit Posted February 4, 2011 Author Share Posted February 4, 2011 Just to be clear, are you saying that the rear door D2 inner door panel can be used as is on D1? I know eg that the D1 uses rods to open the rear door whereas the D2 uses a cable. I suspect the D2 door latch opening may have to be "squared up" to accomodate the D1 door latch? Quote Link to comment Share on other sites More sharing options...
Darren Posted February 4, 2011 Share Posted February 4, 2011 The doors are basically the same, and the inner door card is the same shape on both the DI and DII. However, the position of the inner door catch and the mounting points for the grab handle were moved on the DII to accomodate the new seating arrangement. Quote Link to comment Share on other sites More sharing options...
