RJF Posted February 3, 2011 Share Posted February 3, 2011 Hi, I'm in the middle of sorting out the nasty grinding noise on a '01 TD4. The prop is off and dismantled and the VCU support bearings have been pressed off. My question is about the "flinger" - the folded penny washer/shield that sits between the viscous coupling and the support bearing. The ones on the VCU were a bit mangled and were facing the VCU (large gap between the flinger outer edge and the support bearing face. The replacement bearings are supplied with two of these flingers each (GKN bearings), yet the car was fitted with one each per bearing. How should these flingers be fitted (facing in or out)? I would have thought that facing in would keep any additional grease in, and more crud out. How many of them should be fitted to each end? The workshop manual says to pack the bearing area with heavy grease, but with each end open wouldn't this just get flung out before I got to the end of the road? What do you recommend? Thanks, Rob. Quote Link to comment Share on other sites More sharing options...
jaysjetski Posted February 3, 2011 Share Posted February 3, 2011 my haynes manual shows a picture fitted as the way you found it. however when i replaced mine they were the other way like you think they should be facing the bearing and thats how i refitted. didnt cover in grease though and touch wood no problems for 6000 miles Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 4, 2011 Share Posted February 4, 2011 Fit as per your 2nd picture, flinger facing away from the bearing, and I believe the bearings are sealed units so chances are Mr Haynes has been copy-pasting his bearing-fitting text from an older manual. The flingers are there to deflect the worst of mud & stones from the bearing/seal, not to hold grease in. Quote Link to comment Share on other sites More sharing options...
RJF Posted February 4, 2011 Author Share Posted February 4, 2011 Thanks Quote Link to comment Share on other sites More sharing options...
RJF Posted February 6, 2011 Author Share Posted February 6, 2011 I'm finally back to four wheel drive! Much much quieter than before as well. For interest, I got 2mgg more whilst running 2wd, but I much prefer it in 4wd as designed. Thanks for the help Rob Quote Link to comment Share on other sites More sharing options...
nogard Posted March 5, 2012 Share Posted March 5, 2012 Did you fit two flingers per unit or one? Quote Link to comment Share on other sites More sharing options...
RJF Posted March 6, 2012 Author Share Posted March 6, 2012 Two per bearing, one each side. Quote Link to comment Share on other sites More sharing options...
