wadders Posted February 6, 2011 Share Posted February 6, 2011 Hi there bit of advice required - soz if its in the wrong section. I have recently purchased a rear engined buggy for this years comp safari season. Currently the main part of the harnesses run over the shoulder and through the rear bulk head where they are secured to the roll cage in the engine bay. I have been told that this is no longer acceptable and that I will have to secure them in the cockpit! Is this correct? Any thoughts or advice? Cheers wadders Quote Link to comment Share on other sites More sharing options...
najw Posted February 9, 2011 Share Posted February 9, 2011 Doesn't sound right to me. As long as they are not 3 point then I don't see that the mounting points should have to be moved. Email me if you need pointers who to talk to Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted February 11, 2011 Share Posted February 11, 2011 First of all. How do the shoulder belts get through the bulkhead in to the engine bay? You need a sealed fireproof bulkhead between engine bay and cockpit that will not allow the passage of fluids or fire. Also, the harness belts are made from nylon / polyester, which is not fireproof or heat resistant, so may be damaged by the engines heat, or in the worst case, you get a fire in the engine bay, crash and die as you go through the windscreen with a trail of melted webbing behind you Just looked in the blue book and - "2.1.10. Seat belts once involved in a serious accident should be discarded as they are likely to have stretched. Belts subjected to oil, acid or heat should be replaced." Quote Link to comment Share on other sites More sharing options...
