Smego Posted February 24, 2011 Share Posted February 24, 2011 Can anyone tell me how? Outside ones come of easy but cannot suss the centre one, need it off as selling it. Ta, Gary. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted February 24, 2011 Share Posted February 24, 2011 It's held on by 4 bolts at each corner that go through the floor. You need to remove the seat base and the metal inspection cover (4 screws) to get at the nuts on the other end. Or you could undo from under the vehicle with someone securing the bolts from inside. The two bolts under at the back are under the back rest, so you need to use a spanner instead of a socket. I think they're 13mm. I lost a lot of skin from my knuckles as being underneath, the bolt threads/nuts were quite rusty. Don't want to do it again for a while! Good luck. Quote Link to comment Share on other sites More sharing options...
sgnas Posted February 24, 2011 Share Posted February 24, 2011 Seat base should remove same as the outers. Just lift on the leading edge. However, could be stiffer as it is less likely to be removed. Then it is bolted down at 4 corners. If the nuts are not captive then either get someone underneath to hold with a spanner or remove the panel in the seatbox (4-6 screws) and spanner it yourself. Quote Link to comment Share on other sites More sharing options...
Smego Posted February 24, 2011 Author Share Posted February 24, 2011 Ok maybe it;s got stiff over time as I couldn't lift it at all, will try again at the week-end. Quote Link to comment Share on other sites More sharing options...
slomofo Posted February 26, 2011 Share Posted February 26, 2011 If its been in for a while and the rear nuts are captive, give them a soaking in WD40 or similar - the exposed threads get rusty and seize in the bolt on the way out (and can snap!) Quote Link to comment Share on other sites More sharing options...
Smego Posted February 27, 2011 Author Share Posted February 27, 2011 Thanks for all the advice people, after lifting up the base and the panel it wasn't too hard although I undid the outer seatbelts before I noticed the other bolts in the muck! good clean up now and fitted some camping mat to deaden the noise till me cubby box arrives Off to Brum in the morning to deliver the seat. Quote Link to comment Share on other sites More sharing options...
