geldy Posted March 12, 2011 Share Posted March 12, 2011 was having a problem with miss fire so thought a service would help, done the service run for ten min then died ,tried the recomended bleed proses ,nothin but noticed temp needle when turning ignightion on up in red, also can not hear fuel pump priming. any ideas,cheers dave Quote Link to comment Share on other sites More sharing options...
oakesy Posted March 12, 2011 Share Posted March 12, 2011 was having a problem with miss fire so thought a service would help, done the service run for ten min then died ,tried the recomended bleed proses ,nothin but noticed temp needle when turning ignightion on up in red, also can not hear fuel pump priming. any ideas,cheers dave Engine type first petrol 2.5 v8 carb or efi. Diesel 2.5 td tdi 200 300 td5 etc. would help. Check earthing connections for intermittent fuel pump. If Carbs the idle flow is blocked or poor. Quote Link to comment Share on other sites More sharing options...
geldy Posted March 12, 2011 Author Share Posted March 12, 2011 td5 diesel Quote Link to comment Share on other sites More sharing options...
oakesy Posted March 12, 2011 Share Posted March 12, 2011 td5 diesel Check fuel first if having problem originally. Also the ECU plug for oil contamination if oil the harness will need replacing. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 12, 2011 Share Posted March 12, 2011 Mis-fire (not backfire) is usually the injector wiring loom. Having said that - it doesn't usually affect starting, but general performance above about 1500 revs. Les. Quote Link to comment Share on other sites More sharing options...
Gromit Posted March 14, 2011 Share Posted March 14, 2011 temp needle when turning ignightion on up in red, also can not hear fuel pump priming. any ideas,cheers dave Check the wiring to the yellow relay (fuel pump) under the seat. IIRC, its the one to the front of the 2. Check also the blue connector that joins the 2 looms. Wiggle everything till the relay clicks, the fuel pump starts and the temp needle returns to cold. Quote Link to comment Share on other sites More sharing options...
