r0s5 Posted March 15, 2011 Share Posted March 15, 2011 hi i have a 07 defender puma and he uj joint has worn on my front propshaft only done 30000 anyone know what would cause it and should i replace the whole propshaft regards ross Quote Link to comment Share on other sites More sharing options...
MartinK Posted March 16, 2011 Share Posted March 16, 2011 You may be lucky! There's a recall for Puma's wher ethe grease nipple is not fitted from the factory on the prop shaft: SSM40851 Defender Front and Rear Propshaft Grease Points Models : LD - Defender Title: Defender Front and Rear Propshaft Grease Points Last Modified: 30-MAR-2009 08:27 Category: Noise/ Vibration Symptom: 703000 Vibration Concerns Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles. Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to 8Nm + 45degrees. Other than that, you can re-build the shaft with upgraded bearings, or buy a complete (improved) new assembly and pop it on. For rebuild see here (it's a Disco, but they're pretty much the same): http://www.discovery2.co.uk/propshafts.html For new/improved aftermarket see here: http://www.gwynlewis4x4.co.uk/page36.html Repair or replacement is not as bad as it sounds. You are also supposed to replace the propshaft nuts/bolts (4 each end). I got mine for £2.99 off ebay. If I were you, and was planning to keep the vehicle long-term, I would probably buy a whole heavy duty shaft, and grease it twice a year, knowing it should be fine for the rest of the vehicles life (it will only take a couple of hours to replace. Nuts & Bolts here http://cgi.ebay.co.uk/Land-Rover-Defender-90-110-Prop-Shaft-Nuts-And-Bolts-/300524860177?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45f8ad7311 Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 16, 2011 Share Posted March 16, 2011 you could get some of these. and be a happy chappy Quote Link to comment Share on other sites More sharing options...
