Help, leaking piston on brake servo?
DC_
Well they say it comes in three's so this must be the next thing.
Discovered a drip behind the brake pedal and it looks to be a leaking piston seal?
The rubber boot was quite full so it must have been leaking for a while I suspect. Didn't seem to be losing brake fluid though :unsure:
So help needed to fix it. How big a job is it? I've never done brake servo/piston work before so am a bit scared.
I'll be outside with a cuppa scratching my head.............cheers guys
Charlie
Thanks for the reply blues
It's defo brake fluid, weeping seal, spent the weekend exploring it, and was at a mates who knows his stuff.
New seal may be the way to go considering I've got the ABS brake booster assembly unit :blink:
It's not too bad just now......
Sorry, didn't realise it was ABS, so no vacuum assist. IIRC there are only a couple of seals you can swap then it's a new master/boost unit. I did read there's a company who rebuild them and memory tells me they're in the midlands but I don't recall much more. if you buy a second hand one it needs to come straight off and be fitted to yours.
