seth's dad Posted March 25, 2011 Share Posted March 25, 2011 Evening all, Finally got my 200tdi swapped into my 110 and amazingly it started 1st time, the only problem being after running for a couple of minutes the revs start to die as though being starved of fuel. The engine doesnt cut out and will eventually tick over ok again for another couple of minutes. I have cut and extended the fuel hoses and used the proper fuel pipe clamps. Do you think air is still getting in the pipes or could there be another problem i should be looking at. The lift pipe primed the fuel filter fine so im presuming that that is ok, or am i wrong on that many thanks for any thoughts Quote Link to comment Share on other sites More sharing options...
Chris x Posted March 25, 2011 Share Posted March 25, 2011 I had this problem, although it would die after a few seconds. Mine was drawing air in through one of the joins in the fule line. It wasnt leaking fuel though. Other things could be lift pump or a hole in the pickup pipe in the tank. All suggestions I had when I posted about mine! Quote Link to comment Share on other sites More sharing options...
bluespanner Posted March 25, 2011 Share Posted March 25, 2011 I'd go with air getting in somewhere. Mine does this when its about to run out of juice Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 26, 2011 Share Posted March 26, 2011 I had this problem when I didn't turn in the plastic screw enough on the sedimenter (I was scared of breaking it off). I went mad bleeding everything and eventually just tightened up the screw. I leave the screw alone now and take the sedimenter to bits instead. But your problem is 99% sure to be an air leak. Quote Link to comment Share on other sites More sharing options...
