voevod Posted April 6, 2011 Share Posted April 6, 2011 I may be getting a sankey widetrack in the near future and am confused about what I actually need to bolt on to my rear crossmember.Is it just the hitch itself,or do I need the drop bar as well?And do I need a strengthening plate on the inside of the x-member?sorry if it's been asked before Quote Link to comment Share on other sites More sharing options...
sharpy Posted April 6, 2011 Share Posted April 6, 2011 I may be getting a sankey widetrack in the near future and am confused about what I actually need to bolt on to my rear crossmember.Is it just the hitch itself,or do I need the drop bar as well?And do I need a strengthening plate on the inside of the x-member?sorry if it's been asked before Hiya, I have a nato hitch directly bolted to my rear cross member, inside there is a steel plate abpout 4 mm thick which the bolts go through and the plate is a few inches wider sideways, my sankey sits slightly upwards as i have a three inch lift, the drop plate arangement is as far as i am aware only needed if you have the ball arrangement which is a lot lower Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 6, 2011 Share Posted April 6, 2011 See the tech archive http://forums.lr4x4.com/index.php?showtopic=617 Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 6, 2011 Share Posted April 6, 2011 and here http://forums.lr4x4.com/index.php?showtopic=2690 Quote Link to comment Share on other sites More sharing options...
voevod Posted April 7, 2011 Author Share Posted April 7, 2011 cheers guys,I get it now...wow the hitches aren't cheap are they?! Quote Link to comment Share on other sites More sharing options...
