Bonnet pull cable bracket
Hi I am in the middle of changing my bulkhead on my 300tdi to one from a TD5 and have just noticed that there is not a bracket in the drivers foot well to fit the cable pull to.
The bracket on the 300tdi is welded to the foot well so it cannot be removed.
I have read a lot about this conversion but have never seen anything about the bonnet able pull.
I know a lot of you have done this conversion so any help would be appreciated.
Regards
Frax ;)
Just use a TD5 bonnet release, it's a MUCH better and a more reliable system than the older version IME. You can source the lever from the bay of e and the cable is a couple of quid.
The lever just bolts onto the side of the driver's footwell, the holes will already be there.
If I can help it I would like to leave the 300tdi in one bit as the condition would be worth a repair and posible sell. :D
As for the TD5 Bonnet release I have had a look on ebay but no joy - will keep looking though, is it a diferent cable ? :unsure:
Frax ;)
Found a TD5 one and bought that but have also noticed that there is a bracket next to the heater matrex which hold a fues box with some heavy duty fuses which is also not there. dont think I will find tese for sale.
Thank for yer help.
Frax ;)
