Dorsetfreelander Posted April 20, 2011 Share Posted April 20, 2011 Does anyone know anything about disconnecting the fuel burning heater or even where the sensor is? The one on my 04 reg TD4 SE auto is coming on in temperatures up to around 15C instead of going off around 5C. Thanks Quote Link to comment Share on other sites More sharing options...
RJF Posted April 21, 2011 Share Posted April 21, 2011 I think the sensor is just in front of the radiator and is probably a bumper off job. You could unplug the FBH itself. I think you can get access by removing the wheel liner. Probably the easiest way to disable it would be to pull the fuse. It is fuse5 in the engine compartment fuse box for '01MY, not sure if it's the same for facelifts. Rob. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 23, 2011 Share Posted April 23, 2011 The sensor is on a little bracket behind the lower bumper grille, you can't officially disconnect it wouthout removing the bumper but you can use a long screwdriver and some swearing to pop it out of its holder and feed the sensor & wire back up through into the engine bay & then unplug it. Quote Link to comment Share on other sites More sharing options...
