danster Posted June 4, 2011 Share Posted June 4, 2011 anyone got a diagram showing the drivers door lock on a 96 disco mine just turns and doesnt move anything on the inside of the door think somethings broken but cant tell what? cheers Quote Link to comment Share on other sites More sharing options...
Igol Posted June 5, 2011 Share Posted June 5, 2011 Sounds like the springs snapped. You can pick them up on ebay for a few quid with a fitting guide usually. Quote Link to comment Share on other sites More sharing options...
peterdon Posted June 5, 2011 Share Posted June 5, 2011 I don't think it is the spring, if it was, the interior lock button would come up and then drop down again. Possibly the linkage has come off the lock. Here is a pic of mine when I was changing the spring it may help if you take the door card off and compare. If I'm wrong (it has been known!!!) have a look HERE Quote Link to comment Share on other sites More sharing options...
nicedayforit Posted June 9, 2011 Share Posted June 9, 2011 anyone got a diagram showing the drivers door lock on a 96 disco mine just turns and doesnt move anything on the inside of the door think somethings broken but cant tell what? cheers Section 76 http://www.landy.pl/LandRoverDiscoveryWorkshop1995-1996.pdf Quote Link to comment Share on other sites More sharing options...
leon_81 Posted June 11, 2011 Share Posted June 11, 2011 Does yours have a factory fit alarm? Mine does and the parts that connect the actual lock barrel to the rods going to the latch mech are in 2 parts. 1 turns the other. On mine, the part attached to the lock barrel had snapped, meaning when the key turned it didn't,so didn't move the other one to pull/push the rod Hope that makes sense! Quote Link to comment Share on other sites More sharing options...
