DiscoHere Posted July 23, 2011 Share Posted July 23, 2011 Hi Guys Is there any secret or easy way to take a front door of a Disco 1 or is it just a case of get at it with brute strength and the right size tool. Hugh Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted July 23, 2011 Share Posted July 23, 2011 The electrics unplug from under the panel by the drivers foot well. Then it's unbolt it. BUT!!! I would recommend having a friend or two there, it is not exactly light. Quote Link to comment Share on other sites More sharing options...
doda456 Posted July 23, 2011 Share Posted July 23, 2011 Un plug electrics, either as mentioned or the rubber sleeve(s) in hinge area is easy to prise off to and find the connections, and then just unbolt and lift off, but watch out they are very heavy. 15kg or so When i swapped a door i took off the wing as well because it made access to the hinges really easy Quote Link to comment Share on other sites More sharing options...
redneck Posted July 25, 2011 Share Posted July 25, 2011 Don't unbolt the hinges, mine has c clips on the top of the hinge pins. Remove the c clips and lift off, after disconnecting the electrics first. Quote Link to comment Share on other sites More sharing options...
pw8757 Posted July 26, 2011 Share Posted July 26, 2011 When you put it back on - keep a close eye on it until you re-fix the retention strap...........I managed to let mine foul the front wing and that caused a vertical crease that was a bu**er to fix! Quote Link to comment Share on other sites More sharing options...
