Ian Barrett Posted July 31, 2011 Share Posted July 31, 2011 Hello guys, I've put the Landy back on its wheels after a hard 6 months work sorting out the chassis and brakes only to find the tyres need some air. But the tyres were bought before I converted it to a mohair truck cab roof so I'm after advice on tyre pressures - probably from those of you with truck cabs. I have BFG Trac Edge 235 85 R16 on steel modulars. I've set the tyres to 30psi front and 25psi rear because of the lack of weight at the back. Am I somewhere in the right ballpark? Thanks IanB Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 31, 2011 Share Posted July 31, 2011 I have Trac Edges (245/75/R16) on Discovery Steels and I've always run 32psi front and rear. If I need to stick half a ton in the back I'll bump it up to 40 on the rears Quote Link to comment Share on other sites More sharing options...
gazelle Posted August 1, 2011 Share Posted August 1, 2011 Tyre pressures - Thanks to Nige. Quote Link to comment Share on other sites More sharing options...
