landy andy. Posted September 25, 2011 Share Posted September 25, 2011 The side lights work as they should, with a low current going through to the main head light, but when switch is in the dipped position I have sidelights only no dim headlight. But then, if you switch to main beam, then turn back to dipped they all work fine, till next time you use them. I know there is a box somewhere that controls this low voltage to the headlight business, and am thinking that may be the problem. Any thoughts.......... Where is this box of tricks.......... Thanks Andy Quote Link to comment Share on other sites More sharing options...
western Posted September 25, 2011 Share Posted September 25, 2011 might be a problem with the dim dip relay, it's the pink one behind the instruments in the far right corner. looks like this one [upper item is the resistor, bolted to inner wing rear corner] or might be a faulty main light switch. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted September 25, 2011 Author Share Posted September 25, 2011 Thanks Ralph, It's not the main light switch, tested that, and I did not know where the relay was to be able to check. Will have a look for the resistor thing, havent noticed it before. Thanks Andy Quote Link to comment Share on other sites More sharing options...
Frax Posted September 25, 2011 Share Posted September 25, 2011 Here is the location on the inner wing if you can make it out - you would need to remove you wheel arch to see it. Quote Link to comment Share on other sites More sharing options...
western Posted September 25, 2011 Share Posted September 25, 2011 if you look outboard of the brake servo, in the right rear corner of the engine bay, [vehicles right not yours] you should see the flat rear face of the resistors mounting plate, you'll probably need a good torch as it's not easy to access. Quote Link to comment Share on other sites More sharing options...
western Posted September 25, 2011 Share Posted September 25, 2011 Here is the location on the inner wing if you can make it out - you would need to remove you wheel arch to see it. now that's just cheating, bit drastic taking the whole wing off but shows the item very well. Quote Link to comment Share on other sites More sharing options...
Frax Posted September 25, 2011 Share Posted September 25, 2011 Had it handy as you told me what this thing was............. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted September 25, 2011 Author Share Posted September 25, 2011 Thanks lads, Can it be bypassed? Is it exspensive? Andy Quote Link to comment Share on other sites More sharing options...
western Posted September 25, 2011 Share Posted September 25, 2011 yes it can, by unplugging the relay & making up a short jumper lead to plug in to the relay base to connect the 2 red/blue wires IIRC, I believe Mike [mmgemini] has posted this little dodge in here somewhere, try a search for dim dip threads. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted September 25, 2011 Author Share Posted September 25, 2011 Just making my way through the search results now. I assume that when bypassed, the sidelights will only light when in the sidelight mod, and no dim headlights. Andy Quote Link to comment Share on other sites More sharing options...
western Posted September 25, 2011 Share Posted September 25, 2011 yep, just reverts to normal operation,without dimdip. Quote Link to comment Share on other sites More sharing options...
