wheatfielder Posted November 14, 2011 Share Posted November 14, 2011 I have bought second hand, an old panasonic sub woofer for only a few quid. However I dont know how to wire it up to my Sony CDX head unit. I have the wiring loom with it but can't find anywhere to download a manual, any general help would be much appreciated. Will prob. mount it on the bulkhead behind the cubby box. The loom has a red and a brown earth, and 2 sets of twin speaker cables. Cheers. Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 14, 2011 Share Posted November 14, 2011 Put up some pics. I presume its an active sub? Sounds like red and brown are power - straight to battery maybe, but may want to add a fuse if it doesnt have one internally, and it will be on all of the time unless you add a switch (or relay from an ignition feed i suppose?). Sounds like you will need to splice into the speaker wires to get the sound feed to the sub (some amps have this, and a phono connection facility). I'd be suprised if it doesnt have phono inputs somewhere Quote Link to comment Share on other sites More sharing options...
crowmann Posted November 14, 2011 Share Posted November 14, 2011 Here one I made earlier .... da shizz base yo feelin it? Quote Link to comment Share on other sites More sharing options...
wheatfielder Posted November 14, 2011 Author Share Posted November 14, 2011 Impressive stuff - fear mine is a lot more modest- It is active i'm told, it's about 10 years old. Panasonic CJ-BL150. Easy to fit? Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted November 14, 2011 Share Posted November 14, 2011 You may have issues getting that to fit to a modern headunit. The outputs from your stereo will probably be the RCA kind, and on most modern active subs you would find the same. You may be able to find/make a RCA to open end cable, but I haven't seen one. Sorry can't be of more use. Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 14, 2011 Share Posted November 14, 2011 Some amps will accept an input from the speaker cables of the headunit (wasnt it a kind of low level (phono) / High level input??). I think these were most common when only expensive head units had RCA outputs. This may be one of those i guess? Quote Link to comment Share on other sites More sharing options...
