Mean Green Posted August 9, 2006 Share Posted August 9, 2006 The 200Tdi at work has developed a major problem in as much as the engine does not stop when the ignition is switched off. I assumed the stop solenoid so changed it.... ok for about 2 weeks then started again. The lift pump was changed recently... so I doubt it could be that. What else could be causing the problem ... Injector pump?? Something else? Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2006 Share Posted August 9, 2006 pull the solenoid again & look for very thin slithers of metal, if you find some the injection pump needs a rebuild, the slithers are from the cam/roller that pressurise & distributes the fuel to the injectors, they can & do jam the sollys plunger from moving. Quote Link to comment Share on other sites More sharing options...
