animal Posted November 24, 2011 Share Posted November 24, 2011 Hi I have a PTO hydraulic pump 32L and a milemarker winch with a Eaton motor with integrated brake but I am unable to discover the model of Motor cc/per minute etc, as data plate missing. I plan on running though a spool valve in 3/4" hose. how do I find the correct cc motor for my winch and from where. thanks for any help Marc Quote Link to comment Share on other sites More sharing options...
Team Idris Posted November 25, 2011 Share Posted November 25, 2011 Ask first 4x4 for there standard milemarker or typeR motor flows. They are very helpful indeed. 3/4" pipe would be too big I think. I run 1/2" on the typeR and a sneaky 3/8" valve block. A motor is nearly a pump, so you can still turn the shaft ten times and see how much oil it pumps Quote Link to comment Share on other sites More sharing options...
animal Posted November 25, 2011 Author Share Posted November 25, 2011 Thanks for the reply , I think that my MM winch is of the type fitted to the US Hummer as it has the integrated valve block on a Eaton motor but the Data plate is missing, so I have no way of knowing the cc rate of the motor. What size of motor is fitted to your winch please? thanks Marc Quote Link to comment Share on other sites More sharing options...
