muddy4x4xfar Posted December 2, 2011 Share Posted December 2, 2011 Hi all. Iv got discovery 200tdi. Iv changed headgasket, turbo rebuild , new valves an stems oil seals , started it up an its still smoking blue smoke. Iv no idea wot else i shud check out , please is there any ideas you all might have Many thanks Chris Quote Link to comment Share on other sites More sharing options...
disco_al Posted December 2, 2011 Share Posted December 2, 2011 sounds possibly like it's the rings then. if you've done the valve stem seals, and head gasket that's the only other possibility really - compression test would tell for sure Quote Link to comment Share on other sites More sharing options...
Boydie Posted December 2, 2011 Share Posted December 2, 2011 Agreed, it's your rings . When I stripped down my 300TDi after I blew the head gasket I had to wait for 6 weeks to get the new "evolution" head from the UK, in that time I turned the motor over so that all the pistone were in line -- 1/2 way up the cylinders and made up a very thin mixture of kerosine and engine oil, arround 60% Kero, 40% oil and filled the cylinders. After 6 weeks there was no leakage past the rings so I was confident that the few tiny scores in the 3rd bore were of no consequence. Its nice to be right Quote Link to comment Share on other sites More sharing options...
clown Posted December 2, 2011 Share Posted December 2, 2011 does it smell like oil burning. Quote Link to comment Share on other sites More sharing options...
