LR NUT Posted December 20, 2011 Share Posted December 20, 2011 Hi Folks Im needing my towbar on my Disco 2 to be out a little further away from the rear bumper. The largest tow bar spacer I can find is 50mm! Can you get a larger size than this at all? What does the law state about doubling up spacers is this legal? cheers Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted December 21, 2011 Share Posted December 21, 2011 Sounds like you need a different towbar. More than 50mm would be putting a lot of stress on the fixing bolts Quote Link to comment Share on other sites More sharing options...
zardos Posted December 21, 2011 Share Posted December 21, 2011 For vehicles manufacturer after 1st August 1998 can only have type approved towbars fitted (94/20/EC) So you would have to contact your towbar's manufacturer to see if gained approval with a spacer and how big the spacer could be. My guess that it would not be approved with a spacer as type approved towbars are usually specially designed for a vehicle and should not normally require a spacer. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted December 27, 2011 Share Posted December 27, 2011 LR sold a long-neck towball for the Disco, it had 2 loops on the side for the breakaway cable, I've seen them on DII towbars. Otherwise an Al-Ko towball or a Dixon-Bates "Pinball Wizard" combination hitch. Quote Link to comment Share on other sites More sharing options...
