JimAttrill Posted January 9, 2012 Share Posted January 9, 2012 I have the Defender LR manual and it is pretty incomprehensible about tightening up the nut after changing the oil seal. So there is a crush spacer, and it says you have to check the torque (I presume this is the torque required to turn the diff) at so many kg/cm. How exactly is this done as they don't say how you are actually supposed to measure it except that you need a spring balance. Or is there some sort of easier way? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 9, 2012 Share Posted January 9, 2012 Yes there is. Well published on this and other forums by me. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 9, 2012 Share Posted January 9, 2012 do tne nut up to the same place you undid it from, count the turns and put a center punched hole on the nut i line with one you put in the shaft.. Not that daunting a job really. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 10, 2012 Author Share Posted January 10, 2012 That's what I did last time about ten years ago. So I'll do it again..... Quote Link to comment Share on other sites More sharing options...
