C18RCH Posted February 2, 2012 Share Posted February 2, 2012 My dad needs a new wheel for his series 1 but all his local stockists haven't got them in stock. Does anyone know any where near Sheffield that might stock them? Also, am I right in thinking that wheels off any series landy will fit? Cheers, Rich Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted February 2, 2012 Share Posted February 2, 2012 The difference is the size of the studs - S3 have 16mm studs and larger nuts. The double-ended S1 nuts will nearly go through the holes. However I think late S2a's have the small studs and a larger single ended nut - which is about the outside size of the later nuts - however they would be relying on the cones on the nut to locate the wheel. Quote Link to comment Share on other sites More sharing options...
C18RCH Posted February 3, 2012 Author Share Posted February 3, 2012 Ok, cheers for that. Rich Quote Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2012 Share Posted February 3, 2012 When I was moving my Sankey around I used the S1 Spare wheel and it was almost a perfect match so you may be able to look for some Sankey wheels to do the job people are always selling them on ebay. Jason. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted February 5, 2012 Share Posted February 5, 2012 The difference is the size of the studs - S3 have 16mm studs and larger nuts. The double-ended S1 nuts will nearly go through the holes. However I think late S2a's have the small studs and a larger single ended nut - which is about the outside size of the later nuts - however they would be relying on the cones on the nut to locate the wheel. Are you sure there are any difference in the size of the bolt holes in the wheel itself? Because after fitting series 3 axles to my 80" they still fit perfectly although the bolts are bigger. And I'm sure they are genuine S1 wheels as they are very narrow and have a different depth.. Quote Link to comment Share on other sites More sharing options...
BSF Posted February 6, 2012 Share Posted February 6, 2012 When I acquired my Series 1 it had enormous wide wheels and tyres, not to my liking at all. I found a huge supply of series 1 wheels regularly on EBay for peanuts because everyone else wanted to go the other way. Worth a look and a set only requires a morning with a wire brush, Kurust(or whatever your favourite is) and paint. Quote Link to comment Share on other sites More sharing options...
