Defender Steering Drop Arm Conversion To Discovery Track Rod End
eds
I did my 1st drop arm ball joint at the weekend following the tech archive and found it to go quite smoothly only taking an hour and half. I was expecting the swine to be an all day jobby as I've read it can be. The only delay I had really was the fiddly little boot retaining clip round the top of the boot. In the end the circlip pliers managed to open the clip enough to get it over the boot.
I'd already bought a bearmach ball joint kit before I read about the conversion so went ahead and fitted the repair kit anyway.
Apart from the messing around when I changed my ball joint, the boot never sat on the arm on mine - there was no lip to hold it on. With nothing apart from a zip tie to hold it on it was never going to last long so I did the conversion plus HD steering bar.
So far am well pleased with it and when the time comes to change the joint I know it will straightforward.
Malcolm
