Don Del Posted February 27, 2012 Share Posted February 27, 2012 I want to order rebuild kits for the SU carbs on my '99 V8 Defender Staion Wagon. I need to know the model number and anything else relevant. Checking the SU website the latest V8 LR vehicle they quote for is '85. The last 8 digits of the VIN are XA159828. Cheers, Del Quote Link to comment Share on other sites More sharing options...
stuck Posted February 27, 2012 Share Posted February 27, 2012 Not quite what you are asking for I know but the LR part numbers for the seal kit & the gasket kit are RTC6072 & WZX1505 respectivley. HTH's Mick. Quote Link to comment Share on other sites More sharing options...
Spearos Posted February 27, 2012 Share Posted February 27, 2012 Are the 'ID tags' still on your carbs? I believe one of the dash pot screws normally goes through a little strip of metal with some numbers on - if you have these, give the numbers to Burlen and they'll sort you out. HTH Quote Link to comment Share on other sites More sharing options...
western Posted February 27, 2012 Share Posted February 27, 2012 this might help track the kits you need http://www.sucarb.co.uk/VehicleList.aspx?carManID=74&carModel=V8&carYear= Quote Link to comment Share on other sites More sharing options...
Don Del Posted February 27, 2012 Author Share Posted February 27, 2012 Guys, Many thanks for your input. All sorted now. Del Quote Link to comment Share on other sites More sharing options...
