Dorsetfreelander Posted March 17, 2012 Share Posted March 17, 2012 Does anyone know of an easy way to turn off the fuel burning heater on an 04 reg TD4 Freelander? It's only supposed to come on below 5C but seems to be on well above that ie most of the time. I guess there is a sensor problem but I would rather just disable it for now. Any suggestions? Quote Link to comment Share on other sites More sharing options...
knacker Posted March 17, 2012 Share Posted March 17, 2012 Would like to know this as well, the other halfs is doing the same. Jon. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 17, 2012 Share Posted March 17, 2012 Pull the fuse? There is a temperature sensor in the lower grille in the front bumper (may be different on 04 models but that's where it was on my '01), if you are careful and poke a screwdriver through the grille you can pop the sensor out of its bracket and pull it back up into the engine bay, or pop the connector off. This then gives you access to manually control the heater, I replaced the sensor (which is just a thermo-switch) with an extended wire into the cabin & a switch on the dashboard so I can force the heater on/off manually. I was going to add another option to revert back to the sensor but can't be bothered... you can also activate the heater with the engine off by giving it 12v on that wire, although it won't run for long as it needs the heater fan running, otherwise the heater matrix just gets hot and the FBH switches off again in a very short time. My next project (probably next winter now!) is to wire in the heater blower so I can warm the cab up with the engine off. Quote Link to comment Share on other sites More sharing options...
